A plumber I hired to rough in new plumbing installed the 3 inch pipe in the basement.
The pipe slopes downward nicely at the required pitch as it leaves the house.
There is a small section (a 9 foot run) where the pipe actually slopes up very slightly as seen on a bubble level.
Is this sure to fail?
The plumber said everything will be fine.
Is there a chance everything is fine?
Thanks!
    If that pipe will carry anything other than clean water then it will block sooner or later ... – brhans Nov 29 '17 at 15:14
  • Make him fix it. – Paul Logan Nov 29 '17 at 15:43
  • Everything except code compliance and function. – isherwood Nov 29 '17 at 21:34
There is no reason any sewer pipe should slope upward. Gravity is what it is.
| improve this answer | |
