A couple of small places that were touched-up slightly with the same paint have a bit more of a sheen. Any suggestions to dull it a bit? The touchup was just done today - should I wait a while? Thank you!
    Definitely wait a bit, it needs to not only dry but to cure before you try to degloss it. Wait 2 weeks, then rub lightly with a dry paper towel and see how that goes, progress to scrubbing pad, fine steel wool, etc. until desired sheen is accomplished. Nov 25, 2017 at 23:59
You can try adding matt finish powder. It is not noticeable in color and reduces the shine of paint. The tough part is the level of shine so start small in adding the matt powder, then do a test paint and allow to dry. You must paint this indoors on your tests so get some drywall pieces and if vertical walls, stand the test piece vertical. Horizontal dries faster than vertical and will affect the test of how much matt powder to use. Then add more or less for the shine with each test.
