I'm trying to mount my new LG C7 which has VESA 300 (w) x 200 (h).
I purchased this wall mount which clearly states it is compatible with said VESA mount.
https://www.invisiontvbrackets.com/invisionr-tv-wall-bracket-mount-double-arm-tilt-swivel-24-55-hdtv-dl
However I cannot find any arrangement of the arms in which I can achieve this. I can get the width but not the height, or the height but not the width - never both.
Am I missing something blindingly obvious here?
The diagram attached will help someone cleverer than I figure this out hopefully. enter image description here
  • Are you seeing and taking advantage of the full adjustability of the arms. Can you see the swing in the arms.
    – Paul Logan
    Nov 24, 2017 at 3:39
  • The arms don't actually swing, each arm is able to be mounted in one of two positions on each corner. I managed to get it working simply by losing two of the arms - not sure how orthodox this is though.
    – James
    Nov 24, 2017 at 11:33
I contacted the company directly - for anyone who has this issue in future it requires this configuration:
  • That's the conclusion I drew based on the dimensions shown in the drawing provided. Was the mistake in assuming that only the end holes in each arm were to be used?
    Nov 25, 2017 at 1:01
