I have two wall's light switches I am replacing with new ones.
For one of them, there are 5 wires. Two white (capped and not used), two black and a red. This light switch controls one ceiling light.
Another one has 6 wires, 2 red (connected), 2 white (connected) and 2 black (capped and not used.) This light switch controls two ceiling lights.
The new switch I want to replace with has three slots (two gold and one green).
I have looked through tutorials online but they use examples that don't quite fit my scenarios. For the first picture, I placed the two black into the new switch and connect the red into green. But it doesn't work.
For the second picture, I have no idea how to connect the 4 wires into the new switch that takes only 3.
  • What country are you in?
    – JPhi1618
    Nov 20, 2017 at 20:41
  • I am in Canada.
    – KubiK888
    Nov 20, 2017 at 20:42
  • I should have made this one comment... How many screws does the outlet in the second picture have? If it has 3 screws on the body + the green, its a three-way switch that can be controlled in more that one location
    – JPhi1618
    Nov 20, 2017 at 20:43
  • It has five screws. Two for two red wires and another two for white wires. Then a green one not holding anything
    – KubiK888
    Nov 20, 2017 at 21:18
    kind of frightening seeing a red wire on the ground screw.. Is that a Canadian thing?
    – agentp
    Nov 21, 2017 at 1:34
You might want to hit a library and get a book on electrical wiring and round out your knowledge. You just can't learn solely by asking questions.
Your first switch looks like a straight plain 1-way switch. It ought to work. Are you changing the switch because it stopped working? If so, the problem was not the switch.
Your second switch with the 4 wires surely sounds like a 3-way or 4-way switch. (2-way/3-way in UK English). WATCH OUT.
Recognize and exclude GROUNDs
First, you have a ground wire on most of these. That is good for safety. But it has the side-effect of cluttering up the works and making things seem more complicated than they are. Grounds are simply a web of wire that goes everywhere. They are never part of any circuit (unless something goes wrong, then they save the day).
Green screws must be ground. Ground wires are supposed to be bare, green or green/yellow stripe.
It looks like a few places, they used random scraps of wire to be ground wires, and they weren't all green or bare. A "proper" repair is to replace it with green (or bare but that might short against exposed screws, probably why he changed it). But given your inexperience, you'd be better off just buying a 5-pack of colored electrical tape and mark them green and call it "good enough".
All grounds connect to each other, always, in a big interconnecting web. Make sure that happens. After that, forget about it - exclude grounds from your thinking. We all do. Look at any of our diagrams, no grounds ever drawn. Now it gets simpler by one, and that's often a lot.
Changing? Only focus on the wires ON the switches
You said "there are 5 wires, two unused" -- that is not true. The two neutrals shoved in the back of the box are not part of the deal when changing a switch, and should be disregarded. Don't mess with those. Further, they are not unused, but serve a very important purpose: that book I mentioned will discuss it.
The worst mistake people make is taking apart more stuff than necessary when doing the job. You learn next to nothing and paint yourself into a corner. Happens all the time though, we get "I was changing a (1-way) switch, what do I do with the 10 wires coming out of this box?" /facepalm
Watch out for doubled/extra wires
Sometimes you see 2 wires on a single screw terminal, or 1 on the screw and one on the nearby backstab. This is (mis)using the switch as a junction block also. They mean to join both wires with each other and the switch too, by using the switch's one terminal as a splice block for 2 wires. They should pigtail this instead.
You also see this on almost every receptacle, with 2 wires to each side, but that is allowed.
Watch out for 3-way switches.
3-way switches are completely different types of switches, and devilishly tricky. Aside from ground, they have 3 wires:
  • A single "common" wire with a black screw head
  • two "messengers" with brass screw heads. They are interchangeable, and so you don't need to distinguish them from each other.
The gotcha (part 1) is that position is useless. Take any two 3-way switches, and the positions of the three screws (excluding ground) are always different! So laying them side-by-side and moving one wire at a time to the same position, will not work.
That gotcha (part 2) is that color is also useless. The third wire changes purpose and should/must use the color correct for that purpose, the remaining two are messengers, so it's a dog's breakfast. It's normal, but maddening. I recommend you use the yellow tape in the 5-pack to tag the two messengers. They are interchangeable, no need to distinguish one from another.
So when changing a 3-way, note which is the common (by screw color), tag the other two, and move the common to the new switch's common, then move the messengers.
4-way switches have only messengers - four of them in two pair - two to the blacks and two to the brass. Mark them all yellow, but you can tell which are a pair because they go into the same cable or conduit.
Normal switches only have 2 wires
For a plain mechanical switch, they only have 2 wires (besides ground) and those wires are interchangeable on the switch (they have different functions: always-hot and switched-hot). The switch shorts the two terminals or severs them, that's how a switch works.
  • I just found out that the light controlled by the first switch (with two black and one red wires), it is also controlled by another switch. They need to be both on for the light to be on, is there a way to make it such that each of the switch can independently control the light to be on and off.
    – KubiK888
    Nov 21, 2017 at 0:30
  • @KubiK888 probably not easily. The last guy can make mistakes, but usually does things for a reason. It depends where that red wire goes. I thought it was a pigtail to the metal box, but if it goes off into the wall in a cable, and it goes to the other switch, then maybe. But if so, you'll really want to spend a couple evenings with that book I mentioned. Nov 21, 2017 at 0:45
