The room i want to install some vertical EMT (for data cables) has a horizontal electrical wire (romex or something like it), about 8 or 10 inches from the floor, going across the entire wall as near as I can tell.
Now there is enough give, that I could push the romex to one side and install the conduit, but there is more tension than I would like. Is there any issue with pushing the electrical off center, and rubbing directly against metallic conduit?
