I need to attach this base plate to a stainless steel table in a commercial kitchen. It'd be attached to the top surface off to the side.
It's for a commercial size can-opener.
How do I go about that? Drill holes and then use bolts? Use some special type of screw? Do I need a special drill bit to create the holes?
The tables aren't a solid slab of steel...they're actually pretty thin on the surfaces.
I'm a woodworker...doing anything with steel is way out of my wheelhouse. :)
Here's a photo showing the item attached so you can see what I'm after.
