The hot water stopped running through just one bathroom faucet. (It's a two-handle system). I turned off the hot water supply line valve under the sink and removed the valve inside the handle. But even when I turned the supply line back on, no water came out of the handle. There's a small, short-lived drip from the supply line valve when I open it, but it stops after I shut it. I've never seen anything like this. Any ideas?
Thank you
  • If you disconnect the supply line to the faucet at the shut-off valve and then open the shut-off valve does water come out? Nov 16, 2017 at 22:12
The solution turned out to be disconnecting and reconnecting the inlet side of the supply line, because -- here's the kicker -- the supply line is a Floodsafe line designed to automatically shut off completely if the flow rate exceeds a preset maximum, which I guess I exceeded momentarily. I didn't see the labeling on the supply line until after I disconnected it, and this is the first time it happened in 1.5 years of living here. Frankly, I don't see the advantage of this. It won't do anything to stop common slow, drippy leaks.
  • Floodsafe will stop a catastrophic leak and these can be very costly. In my neighborhood one house was flooded due to a plumber cracking the plastic fitting on the bottom of a toilet tank. It ruptured while the owner was away for a week. IIRC $20k in damage. I installed Floodsafe clothes washer lines for an elderly neighbor, but apparently these increased the filling time of the washer and he had me take them out and put in standard. A tenant of ours caused a flood in a rental property which Floodsafe washer lines would have stopped. Nov 17, 2017 at 16:54
  • To Jim: I guess I'm not clear how it would help in a sink unless the actual 1-foot supply line ruptured or if the valve in the faucet handle "blew up." Any rupture before the line wouldn't cause a shut off. A broken toilet tank, that I can understand. Just curious.
    – Steve
    Nov 17, 2017 at 17:25
  • Rupture of supply lines to clothes washers is evidently a major cause of water damage in houses. I think this must have been the original application for Floodsafe hoses, but clearly could be extended to other water outlets. One has to be careful to slowly open the valve feeding a Floodsafe supply line so that a sudden in-rush of water does not trip the shut-off. Nov 18, 2017 at 12:25
Must be one of these:
  1. The faucet is plugged somewhere before the faucet valve (that you removed). Disconnecting the supply line (described below) should confirm.
  2. The connection from the shutoff valve under the sink to the faucet (the supply line) is plugged. They're often plastic or steel braided lines and are replaceable, try removing it and see if it's clogged or the water now runs through (either out of the shutoff valve directly, or the end of the connection line). Like the braided stainless steel lines in this image, that curve around from the shutoff valves to the copper faucet attachments:
  3. The shutoff valve itself is plugged. If it's the type with a removable washer, try taking it apart and see if it's ok, but TURN OFF THE HOT WATER FIRST! Once you take apart the valve water will spray out uncontrollably. You probably need a friend at the main hot water shutoff valve to briefly turn on the water to see if it comes out.
    Like this type (from Home Depot) where you unscrew the part just under the handle then the "innards" unscrew:
    Apparently it's called the "packing nut" you want to unscrew, then the valve stem & everything unscrews, like in these images:
    enter image description hereenter image description here (But don't remove the shutoff valve unless you absolutely have to, the washers/packing is easy to replace, even the whole valve stem & "innards" usually match new parts.)
    If it's a quarter-turn ball valve they don't generally come apart, but you might be able to try putting a pipe cleaner or tooth pick (something non-scratching) through the open valve to see if it's unblocked.
  4. The hot water line running to the bathroom is plugged somewhere. Does the shower still have hot water? They usually share the same line closely. If the shower's hot then it could be some damaged pipe/line inside the walls somewhere, and a plumber is in your future.
  5. All the hot water in the house is off. Turn it on.
  • Thanks. I will run through the suggestions options and see what happens.
    – Steve
    Nov 17, 2017 at 0:18
  • I'd expect it's plugged somewhere in the faucet itself yet, or all the hot water's off somehow. Don't forget to have towels handy, maybe a bucket too, and a helper on standby to shut off all the hot water is a good idea in case anything goes wrong with the shutoff valve.
    – Xen2050
    Nov 17, 2017 at 0:23
