Caught workers using the uninstalled toilet bowl I bought a week ago, as a stepping stool. I know that porcelain is fragile and deadly when they break under stress, how do i know that one is broken or safe?
How are they deadly?– CactusCakeNov 16, 2017 at 21:48
Was it still packed in its box?– Paul LoganNov 16, 2017 at 22:40
Nope, its sealed in some plastic wrap. I can't return it i think, doesn't look like anything wrong with it. It's deadly if using it and it breaks apart, it's one of my fears.– AltobanNov 16, 2017 at 22:48
Just to reiterate, toilet porcelain is not fragile, and isn't deadly when it breaks under stress. The note below about how hard they are to break is accurate. If you see any damage (ie, scratches), deal with that, but otherwise the toilet is fine.– Aloysius DefenestrateNov 17, 2017 at 0:51
i step on toilets all the time, never had an issue...– dandavisNov 17, 2017 at 20:17
I'd try giving the main contractor (the person you're paying) a stern earfull about how you don't want their workers using your brand new toilet as a step-stool. Maybe say something like if you catch them doing it again you're not paying for that toilet, or they're fired, etc.
They're supposed be professionals and use ladders and stuff, besides the idiot worker could easily fall & hurt himself and your property.
Plastic wrap won't really protect porcelain from much more than dust, a dirty boot with a rock in the bottom could easily scratch it. Might even want to unwrap it some & carefully inspect the "stepped on area" for any hints of damage. Do be careful not to scratch it yourself though, especially if any workers are watching, even a sharp bit on a ring, or house key, or piece of rock on your hands could scratch it, and if it is scratched you could demand it be replaced since it is damaged.
I'm quite sure that porcelain is only broken when it's cracked, so if you don't see any cracks it isn't broken. Toilets are really very sturdy, they're supposed to hold the heaviest people who use them, and almost everyone drops closed heavy toilet seats (even though they probably shouldn't). The next time someone's throwing out an old toilet, ask if you can smash it up with a hammer, you'll find they're quite sturdy (the local garbage here will accept broken porcelain in a box for no charge, but wanted $10 to take a whole toilet).
Just an idea, but there are some special dyes used for detecting cracks in metal, I suppose you could try using one of those on the toilet.
You could try using a stainless steel toilet if you really don't like porcelain, though I'd imagine it would be a lot more expensive, just from it's rarity, or maybe an RV or boat toilet (plastic or metal) is another option. You're also always sitting on the plastic/wood seat, that's on top of the toilet, so even if the toilet cracks you should still be on the seat anyway...
This is not the kind of stress that typically will damage a toilet. It would take some pretty sharp smacks with a blunt object to initiate an internal crack. (I have broken a bowl bolting it to the wall.) Those things are strong. If the surface finish has not been compromised beyond your taste, I doubt you will see and long term effects. (I would hate to be on the other end of that dressing-down)
