I've finally gotten around to installing an outlet into my kitchen cabinets that were put in by the previous owners. Below is a picture of what I am working with.
As you can see the wire is already there but there seems to be no cutout or anything, along with a gap between the cabinet and wall. I have an Old Work box from a previous project but will that work? Or is there a box or method specifically for this kind of job? Thank you!
********************************* Completed ***********************************
Here is the finished product for anyone who is interested:
  • would you want to use a surface mount box for this sort of work? It would take away some interior volume from the cabinet, but it'd work.
    – Aaron
    Nov 15 '17 at 23:01
  • @Aaron I've never heard of a surface mount box, do you have a recommendation of one? I don't mind losing some space if it means less cutting!
    – Derek D
    Nov 15 '17 at 23:04
  • i.ytimg.com/vi/_hVwczZ2PFM/maxresdefault.jpg something like that except obviously with the wire not coming out of the wall and into the box, but all behind/in the box
    – Aaron
    Nov 15 '17 at 23:08
  • @aaron that looks kinda-not-codey. Nov 16 '17 at 1:04
    @Harper I know, I couldn't find one that was done correctly but having the box protrude into the cabinet is the right "idea", or at least the idea I was trying to convey for this example.
    – Aaron
    Nov 16 '17 at 1:06
I would use and 4-square commercial metal box, available from the big box stores or any home center/large hardware store. Knock out a hole in the back of the box, insert a pop-in NM connector install the wire through the connector and screw the box to the back of the cabinet. Purchase a single gang mud ring. install the ring on the box. Install the receptacle and the plate.
  • What is a pop-in NM connector?
    – Derek D
    Nov 15 '17 at 23:41
    Walk in to a proper electrical supply house. "What is a pop-in NM connector?" "What are you trying to do?" "Bring Romex into a knockout on a metal box." "Be right back."....."It's one of these." The exact same conversation will happen at Home Depot, except he'll bring you the wrong thing. Probably a can of paint. Nov 16 '17 at 1:07
  • Non-metallic quick fit NM cable connector.
    – Paul Logan
    Nov 16 '17 at 16:12
  • AKA push button connector
    – Paul Logan
    Nov 16 '17 at 16:13
    In case anyone is wondering how I solved this. As @Harper said, I went to a local electrical supply store, the man working there was incredibly knowledgeable, told me everything I wanted to know, and sold me what I needed. He gave me everything described above and actually threw in some extra stuff for free. For sure a better place to get the knowledge I needed than the local Big Box.
    – Derek D
    Nov 17 '17 at 22:12
