I have a Fridgidaire Gallery Model: FGHN2866PF0.
The issue I have is that the fridge powers off for hours at a time and sometimes days at a time. No cooling, no lights in fridge. Only the door control panel stays alive.
The inner door control panel stays lit with the codes OF OF on the Fridge and freezer temperature readings.
I've changed the main board 3 times. and the control panel as well. Each time the problem returns after 1 month.
I don't know what else may be causing the issue. It's not the home breaker popping, because the display stay lit.
When the fridge comes back to life, the high temperature alarms go off, the ice maker begins to make ice, the compressor comes on, the lights come on.
What could be wrong?
