  1. Is shimming a robust way of securing toilets and avoiding rocking, or is there a better way?
  2. Is any distance between the water tank and the wall behind the toilet a problem that needs bracing?
  3. Are 2 bolts enough for securing a toilet or should all 4 bolts be used when available?
1: Are 2 bolts enough for securing a toilet or should all 4 bolts be used when available?
I have not seen toilets with 4 bolts - only 2 bolts. 2 should be fine if the toilet is installed correctly. Level with the floor and attached to the flange spud. You should have a wax ring (although you might have a wax ring and a spacer - check for exactly what you have - you might take some pictures and post.
2: Is shimming a robust way of securing toilets and avoiding rocking, or is there a better way?
The real issue here is why do you need to shim the toilet in the first place. How much rocking do you have ?... Does your toilet flange have a spacer attached to it ? If so remove the spacer.
Did you remove the old wax ring before installing a new one ?
How does your floor level sit - did someone change out the flooring and not set it correctly or install it with out leveling with the toilet flange. I have seen ceramic tile that had mastic 2 inches thick in order to have the floor height match the toilet drain spud.
You can use wooden shims or better yet the plastic ones - but first make sure you really need the shims. I re-did my bathroom with new ceramic tile - when I installed the tile I made sure the toilet level would be fine with the tile - some people don't think this far ahead.
3: Is any distance between the water tank and the wall behind the toilet a problem that needs bracing?
There should not be if the toilet is assembled correctly - again the key is correctly assembling the toilet. The Tank has 2 bolts and a rubber seal - install the seal correctly and make sure it is seated properly - wiggle the tank a bit to make sure it seats - tighten your tank screws (be careful as you can break the tank) a slight rock is not an issue - and it will move slightly.
Some videos that might be helpful to you ..
https://www.youtube.com/watch?v=Y_hVZ3rPzm4
https://www.youtube.com/watch?v=wM-6bgV7G5s
  • 1) The toilets in this house are probably the originals, and they have 2 bolts for the flange and 2 others (sometimes not used) for the floor further away from the wall. 2) The flange is flush with the top of the redone and pretty flat ceramic tiles, but the toilet always rocked, getting worse over time, and recently caused bad leaks. 3) The water tank is close to the wall but still allows some play; should the tank also be braced or should the focus be on stabilizing the base?
    – adatum
    Commented Nov 11, 2017 at 19:52
  • @adatum stabilize the base unit. Check for spacers, and extra wax rings - the second video shows you how the level of the flange should be and that the flange gets secured to the floor. You might have a leak at the pipe though if the toilet always rocked - pipe not fixed it is flexing when rocking and if it is pvc you can probably guess it is broken - there is a flange that can be inserted into a cracked drain pipe and at least save you from tearing that part up. You need to examine what you have closely - maybe post some pictures ..
    – Ken
    Commented Nov 11, 2017 at 21:58
    Unfortunately/fortunately a family member fixed it before I could take pictures. The toilet base is stable now (4 bolts, no shims). The closet flange and tile are solid (redone years ago). It's good to know the water tank can move a bit. The distance between the tank and wall seems close to perfect now with the base stabilized.
    – adatum
    Commented Nov 16, 2017 at 4:52
