Bathroom light switch and a fan switch and GFI test/reset outlet are located together under one wall cover plate. Hairdryer trips circuit breaker and we have to reset from main breaker panel. Shouldn't we be able to reset from GFI outlet in bathroom?
Somehow the wall cover plate broke and light switch became loose causing a safety hazard. I want to replace the GFI test and reset outlet too, what kind should I get?
