I have a cold-mount vacuum press which is basically a flexible mat bottom and a glass top that closes around material and then a vacuum pump sucks the air out, pulling the flexible bottom up against the top, smooshing whatever is in there. I use it to glue various things to various other things. Well I was using it to glue a paper thing to a wood thing and I broke the glass. It got destroyed in spectacular loud implosion fashion. The glass measures 49”x69”x1/4” thick. I do not want to replace it with glass though, because I want to continue to smoosh all sorts of things together and I will definitely break the glass again!
The material needs to be 1/4” thick or thinner, because of the hinges, although I could replace the hinges if I was really motivated.
I was looking at aluminum which I can get for about $250 for 5052 plate.
Anyone have ideas about rigid light material I could use? Preferably cheap - price is the only reason I’m asking the question instead of just buying the aluminum.
  • Why not acrylic plastic sheet?
    – bib
    Nov 5 '17 at 11:56
  • @bib I’m concerned that the same forces that broke 1/4” glass will crack acrylic. I have no experience with it though.
    – jqning
    Nov 5 '17 at 19:44
  • lexan will not break. it can stop shotgun blasts. there are other even stronger materials, but they get pricey.
    – dandavis
    Nov 7 '17 at 2:57
