So I have a wall I would like to remove in my house (see picture 1-3). I did some exploratory surgery (aka cut holes) in the drywall to see what I was dealing with. This wall is running parallel to the floor joists above (see picture 4): score +1 for being non-load bearing.
However there is a large double 2X10 header above the entry way (see picture 4) in this wall supported by a jack stud on either end (see picture 5): score +1 for being load bearing.
I thought long and hard at what this might possibly be supporting. The house is two stories resting on a concrete block foundation (so three floors if you count the basement). The floor in question is on the middle/first/ground floor. Above this wall I want to remove, is another wall on the second floor offset by ~4 inches from the joist directly above the wall I would like to remove on the first floor. The wall above on the second floor is definitely supporting a portion of an A-frame (not truss) roof above (see picture 6). So is it possible that the wall I want to remove with the header on the first floor is also helping support the roof through the wall on the second floor?
To simplify: my question has two parts:
1) Is this a load bearing wall?
2) If the wall is load bearing, how would I temporarily support the joist above (to install a longer spanned header) since it is running parallel to the floor joists above?
Thanks for your input!
*Update 8/7/18 I ended up knocking this wall out with no issues. I dont believe the wall was load bearing because there were 2 sistered 2X10 above this wall with a span of 9 feet between supports I put in a LAM beam adjacent the overhead joists just to be safe. Now there's two sistered 2X10s with another 2 sistered 2X10 Lams up there. I'm sure this was overkill.
Picture 1
Picture 2
test
    A 2x10 header doesn't necessarily mean that the wall is load-bearing. The carpenter may have just wanted to ensure that the doorway didn't sag and was horizontally rigid. From everything else you describe it does seem like it's a non load-bearing wall, but you already knew that. What else can we tell you? Hire someone local for an hour and get on with your project. – isherwood Nov 5 '17 at 2:30
  • Thanks for your comment. I suspect you are right, since the entryway span is 5 feet, sagging with cripple stud framing could be a potential problem and would make sense to use a rigid header. – Gdogbiskit Nov 5 '17 at 12:29
Picture 2 clearly shows the relation of front door to “wall I want to remove”. The wall you want to remove is a bearing wall ... supporting the roof as shown in last Picture #7, from the exterior.
That one small opening you’ve cut in the ceiling in Pictures #1 and #3 shows something spanning the opposite direction you’re indicating the joists run. You’d better check that again, as I suspect you’re wrong on the direction the second floor joists span too.
Also, when you start removing walls (bearing or otherwise) you’d better make sure you’re not removing a shear wall. Just because it doesn’t have plywood on it, doesn’t mean it’s not a shear wall. Gypsum board is rated as shear panels too and this is a main wall, so I suspect this is a shear wall...depending on what seismic zone you live in.
I like your opening comment, “...before hiring a structural engineer/ architect...”. Now make sure you do it...
By the way, I’d recommend a STRUCTURAL engineer, not a CIVIL engineer...or an architect with a structural background.
  • Thank you for your comment. I could be wrong, but the odds of it being an interior shear wall seems pretty low. I forgot to mention this house is in Western Pennsylvania, which is not frequented by hurricanes or earthquakes. Also, I am certain about the direction of the overhead floor joists being parallel to this wall. I've cut holes in the ceiling on both sides of the wall and confirmed. – Gdogbiskit Nov 5 '17 at 12:14
  • I would agree that it is a load bearing wall the ceiling hole shows the direction of the 2x? Above the header, the wall could be replaced with a larger header across the opening. I did this using at my last home to open up my basement. – Ed Beal Nov 5 '17 at 15:37
  • Pictures 1 and 3 do show something spanning the opposite (perpendicular) to the joist direction I have indicated. However don't let this fool you it is a metal end cap for a HVAC return. This joist bay was being utilized as a return from the upstairs. – Gdogbiskit Nov 5 '17 at 17:11
