My high-rise apartment building has gigabit internet service available via copper ethernet at the communication closet on my floor, but it's my responsibility to establish the connection from that closet to my unit. There is a single cat5e cable into my unit from the communication closet. It was intended for telephone service and is daisy-chained between my three phone jacks.
As I understand it, I have a few options with various pros/cons:
1. Wired ethernet to computer, daisy-chained over existing cat5e: Use the existing cat5e connection to my unit and terminate it to a wired gigabit ethernet connection at an existing phone jack.
Pros:
- Requires no additional wiring to the closet.
- Low cost.
- This is what everyone else in the building has done.
Cons:
- Daisy-chained jacks and questionable quality of existing cat5e wiring may limit speed to 100 Mbps.
- Intermediate jacks in chain will have to be rewired so all eight wires are connected at the jack I want to use.
- Traditional landline telephone service won't be possible anymore but VOIP is an option.
- Two of three existing jacks won't serve any purpose and will be unusable.
- Poorly located jacks for wired computers. Phone jacks are in poor locations, like high on the wall in the kitchen, which could require me to run wires across the room or along walls (ugly).
2. All-wireless network: Use 802.11ac WiFi and place router at first jack in daisy-chain
Pros:
- Moderate cost. (Will require additional Wi-Fi equipment but will be DYI.)
- No issues with jack locations.
Cons:
- Potential wireless interference issues impacting speed. I don't have issues now, but most of the internet seems to agree that wired is better.
- Would have to buy new 802.11ac router and potentially network cards.
3. Dedicated wired connection: Run a new dedicated cat5e or cat6 connection to the communication closet and install a separate jack solely for internet.
Pros:
- New wiring, reliable gigabit speed. Potential upgradability to greater speeds in the future if using cat6.
- Will not impact existing phone lines.
- I can have the jack exactly where I want it.
Cons:
- High cost. Building management likely will require a certified electrician to do the work and hundreds of $$ of deposits.
- High effort. May be difficult due to running cable through existing walls. Will require approvals from building management to run cabling through common areas including a 30-day permitting process.
- Could require (ugly) exposed conduit
I have reviewed previous questions such as the following, but I'm not sure these are the best approach given my particular constraints as outlined above. I'm looking for the best way to accomplish reliable gigabit ethernet given the constraints of existing wiring and cost.
Previous questions: How can I convert Cat5e wired sockets to Ethernet? How can I modify telephone Cat5 cables and jacks into Ethernet ports?
