I've moved into a new home and the shower arm in one of the showers has recently come detached from the shower wall. It appears that the threaded pipe is sticking out too far from the shower wall, and thus the previous owner had used some form of adhesive to attach the shower arm to the shower wall (you can see some gunky yellowish stuff in the photos).
I want to reattach the shower arm to the shower wall, but I'm hoping there is a more appropriate method than using an adhesive. I'd really appreciate some advice on the following 3 potential options:
1) Replace the shower arm with a new normal diameter shower arm that can fit a standard shower arm flange or escutcheon. But if it do this, I'm still concerned that the flange/escutcheon won't lay flush with the shower wall because of the protruding threaded pipe.
2) Try to find a shower flange/escutcheon that will work with the bizarrely large and shaped shower arm/head in the photo. I can't seem to find any information on this type of shower arm and have no idea what type of flange/escutcheon would work.
3) Try to cut the threaded pipe down to size so that a flange/escutcheon would lay flush with the wall, though I'd need too make sure that there is enough thread on the pipe to allow such a cut.
Any other suggestions?
Shower arm photo 1 Shower arm photo 2
UPDATE IN RESPONSE TO QUESTIONS:
Thanks for the quick response! The county is the US (Seattle, WA). I removed the shower arm from the shower wall in order to get better photos and learn more. The threaded tube coming from the wall appears to be a standard pipe nipple, about 2cm diameter (about 3/4 in) and probably about 3-in long. I say probably because I was not able to unscrew it from the shower arm, but I was able to unscrew the whole assembly from the water pipe behind the wall. New photos are below. Now I'm thinking I should just buy a shorter nipple and a new shower flange/escutcheon and shower arm - what do you think?
shower wall shower arm removed pipe nipple
UPDATE AFTER INSTALLING NEW SHOWER ARM
So I installed a new shower arm tonight (photos below) and have a few follow up questions:
1) In the end I opted not to use the brass pipe nipple and connected the new chrome shower arm directly to the threaded pipe in the shower wall (after wrapping the thread with new Teflon tape). Is this okay to do or do I need to use the brass nipple extender in order to ensure a proper/secure fit?
2) The shower arm wobbles around (which is another reason I assume the previous owner used an adhesive to fix the shower arm to the wall). I'm assuming this is because the elbow connector behind the tile has not been appropriately mounted to a stud. Any suggestions for stabilizing the shower arm so that it doesn't move around? The only thing I could think of was to use expansion form behind the shower flange.
  • What is the country? Nov 2, 2017 at 10:22
  • In the USA normally in a shower the tube coming out of the wall is threaded into a fitting inside the wall, and that tubing has a decorative finish and a bezel slides on so that it is easy to make it flush with the wall. This arrangement looks more like the US set up for a tub spigot which is some significant trouble to get to fit exactly. Tub spigots have to be cut-off at exactly the right length for a specific spigot and then have a fitting sweat soldered on so that when the spigot is screwed on it ends up close to the finished wall. Nov 2, 2017 at 11:33
    How is this shower arm attached to the copper tube, e.g., threaded on or slid on with O-ring seal . . . ? Nov 2, 2017 at 11:38
  • As far as the wobbly shower arm the best way to fix it is fasten the pipe in the wall to a stud, unfortunately that's not really an option in your situation unless you remove some tile. I would pack the opening with silicone,I would not use foam. If you clean everything well it will bond to the tile and to the pipe and should keep it from moving side to side as well as front to back. Do not silicone the plate. Nov 3, 2017 at 15:25
  • Thanks! When you say silicone, do you mean like the silicone caulk that you would use in a shower, or a different type of silicone sealant?
    – Eli Kern
    Nov 3, 2017 at 20:29
The nipple going to the shower head is too long. A simple fix is to measure the gap, then remove the nipple and deduct the gap distance and purchase a new one. I would recommend a brass nipple because there will be less issues with dissimilar metals that can eat away at the pipe or shower fixture.
If you cannot find the right length a new nipple can be made using 1/2" copper and 2 male threads. This will require some cutting and soldering but the exact length can be made if needed. Get some Teflon pipe tape or liquid sealant and coat the new nipple threads. I install the pipe into the wall first and snug it down then the shower head assembly. Use caution when tightening because you don't know how the elbow or 90 in the wall is anchored.
  • Thanks so much! I'll head out to the store tonight and buy a new nipple and will update with my progress later.
    – Eli Kern
    Nov 2, 2017 at 23:46
The picture below is of the type of fitting you likely have in the wall. Normally these are fastened to a stud or spacer which holds the pipe solid and allows you to tighten your extension pipe securely without worrying about damaging the piping behind the wall. You may be able to see through the hole to confirm you have this type of fitting and that it is anchored with a screw in each "foot."
  • I agree that this is the correct fitting for a penetration into a shower but many times I find only a standard elbow and no anchor at all some times plumbers tape a metal strap with holes on copper (in several cases the dissimilar metals caused the leak) it should be this type but may not be is my caution.
    Nov 6, 2017 at 14:07
