Is it okay to put a tv on top of a gas logs fireplace? I am concerned since the emitted gases must be making the walls hot?
  • Is there a circulation fan on the gas fireplace that blows the warm air into the room?
    – Dotes
    Nov 2, 2017 at 1:45
  • There is none. This is gas logs fireplace. I don't believe it has fans. I haven't started it even once after buying the house last year since I haven't installed a proper switch. Right now the only way to start is using a knob and a lighter. Nov 2, 2017 at 1:47
I say no. THat TV is full of PC boards. Printed circuitry hates heat. Good quality computers have a half dozen cooling fans.
