Can I put them on the same circuit or do I need separate circuits?
  • Please only ask one question at a time. Your second question is a duplicate of this question so I removed it
    – Machavity
    Nov 1 '17 at 13:51
Yes, interior and exterior lights can be on the same circuit. The same circuit breaker that works for my family room also works for my porch.
And yes, GFCI and non-GFCI can also be on the same circuit. Typically they recommend that the GFCI outlet is the first receptacle connected to a circuit so if it trips, it cuts off power to the rest of the circuit since current will not travel through the neutral to the other leads.
