My toilet tank takes 2 min 11 sec to refill. It uses the Fluidmaster 400A. Water pressure is good and we don't have hard water or sediment. Does the 400A have a flow restrictor in the shank? I would like to speed up the fill time considerably.
    Instructions for the model just above the 400A: fluidmaster.com/toilet-problems/… – Tyson Oct 31 '17 at 23:47
    Sounds dumb, but I found this issue in my house - make sure the valve is turned all the way on. – JPhi1618 Nov 1 '17 at 14:34
    I’m voting to close this question because it's an old question with no accepted answer from a no-longer user. – FreeMan Aug 1 at 17:27
No, no re-stricter but there is a screen in the fill tube. I'll bet it is plugged with debris. Happy Hunting P.
| improve this answer | |
