My kitchen is an extension. I want to put ceiling hooks up there so I can hang pans from the ceiling.
I need to know where the rafters are so I'm not just putting hooks into the plaster. There is no access to the loft space.
Sign up to join this communityMy kitchen is an extension. I want to put ceiling hooks up there so I can hang pans from the ceiling.
I like the rubber insulated handle of my screw driver as a knocking tool. The rubber handle of a hammer works well, won't mar the ceiling. A small finish nail leaves very little hole behind. (Happy Hunting) I carry an electronic stud finder as well. The newer stud finders are pretty amazing, fab results. You don't need an expensive finder for impressive results. I would avoid the low, low end models.
