I was hoping to get some advice on the proper setup for this system. I live in Long Island, NY and just moved into a large house with an extremely old oil burner and 3 a/c condensers. I'm about to start an oil to gas conversion ... when I was introduced to this brand new Bosch inverter ducted heat pump, which is amazingly efficient.
I thought to myself ... since I'm putting up solar panels anyway, maybe this would be the best way to go about it. But winters might be cold, so I was thinking of using a tankless Navien combi to run a hydronic coil in the air handler to supplement. But it's hard to find people talking about heat pump + hydronic coils, as it's not very common ... although I'm not sure why not since so many people are putting up solar panels nowadays.
But I was wondering if anyone could provide their thoughts on this setup and what I should be careful of. Yes, I know that natural gas is really cheap right now, but 2 5-ton heat pumps should be able to replace the heating and cooling ... I think.
Or am I completely wrong and should just install a conventional gas boiler to heat my large home? And leave my a/c system as is since it's still working.
