I would like to install a GFCI outlet in my bathroom. I attempted to install it beside our vanity mirror on first the left then the right side, but was unable to due to the construction of the wall, where the studs where placed too closely together. So, I decided to place the outlet on the wall opposite of the sink. My question is, how high from the floor should I place this outlet?
Thanks
11
  • Are you trying to install a new receptacle in a wall, or are you converting an existing receptacle to GFCI? – Harper - Reinstate Monica Oct 30 '17 at 14:51
  • I am installing a new receptacle. This bathroom did not have any receptacles when we purchased the home. – JasonQ Oct 30 '17 at 14:57
  • Reason I ask is 99% of GFCI questions relate to the difference, so GFCI in the title tends to draw people good at solving those problems. In your case it's entirely a construction question... – Harper - Reinstate Monica Oct 30 '17 at 15:02
  • So it doesn't matter how high off the floor? I was worried that the typical 16 inches was not high enough for a bathroom. – JasonQ Oct 30 '17 at 15:07
  • To be clearer, your title is confusing as to whether you are upgrading to GFCI. I would suggest simply removing "GFCI" from the title. I don't know the answer to your question, but the edit I suggest will help draw construction folks instead of electrical folks like me. – Harper - Reinstate Monica Oct 30 '17 at 15:14
On a wall there is not a minimum or maximum height. The question would be how high would you like it? If close to the basin they are usually placed several inches above the counter space but again no code height restriction on the walls. The one thing is it can not be placed in a wet location like above a tub unless outside the tub zone.
