My stairs are creeky and squeaky. They are probably as old as the house (100+ years) so they are probably full of lose nails, but still i‘d like to remove as much sound as possible.
I took off the drywall and found that screws have been added to the risers and treads. And some blocks have been placed under the treads. My current thinking is that i need to glue and screw a 2x4 under each tread. Would bracing betweeen the stringers also help?
Any other tips or tricks?
under tread
stairs
underside
  • Squeak is spelled s-q-u-e-a-k.
    – Rob
    Oct 29, 2017 at 14:44
  • Thought that didn’t look right! Fixed. Oct 29, 2017 at 15:04
If there are gaps between the stair parts, pumping them full of polyurethane construction adhesive would help a lot.
If you add 2x4's under each tread, put them in with the 1.5" side horizontal and the 3.5" side vertical.
  • I saw a youtube video where they made a U-shape out of 2x6 for each tread, and then glued and screwed them in. Think the side parts are needed? Oct 29, 2017 at 15:03
    I went with gluing and screwing 2x6’s. I used PL Premium for ashesive, which i think is polyurethane. Anyways, it’s seriously strong. I’ve only done the first 4 steps and they are now silent. Nov 11, 2017 at 3:46
