This summer, we moved into a home that has sub-floor heating installed. However, I have no idea how to use the boiler or turn it on.
The boiler itself (a Slant/Finn Victory II gas-fired boiler) has made some noise since we moved in but the thermostat was always set to the lowest position.
However, this morning I set the thermostat to 70 in the hopes that is all we would need to do. When checking the gauges on the boiler, though, I see the pressure at 0 PSI and temperature at 0 as well.
There is a small box toward the bottom of the boiler with a dial that offers Off, On, and C positions; it has been set to On the whole time.
What do I need to do to get the heat turned on?
Thank you!
EDIT I did check our propane tank (60%) and all water valves appear to be on. I tried the reset on the boiler, per the instructions on the unit itself.
When turning the thermostat up, the unit does kick in and I can hear the electic ignition firing repeatedly. It wasn't doing that this morning. However, it does not appear to be igniting. I will keep an eye on it, but still very interested in your expert advice.
  • You probably have 2 issues. 1 with with the wiring/safety switches/gas valve, and the other probably with the pressure reducing valve not letting water in. Don't try to fire a boiler with 0 psi although it could be that the gage is broken, call a professional. – aofkj Oct 29 '17 at 4:19
  • @aofkj Thank you for the reply. I actually tracked the issue to the gas line coming into the house: there's no gas coming into the house. That being said, would that also cause the pressure gauge to show 0? Shouldn't there still be some water pressure? – Zephyr Oct 29 '17 at 11:20
  • It's a completely different issue, check reducing valve and the other (ball/gate )vave. – aofkj Oct 29 '17 at 12:38
