27
Currently this is what my doorknob looks like below
I was trying to change out my doorknob and left both sides inside of the room but the AC kicked on and shut the door on me and now I am stuck outside of the room. I was wondering how I could I open the door?
My current doorknob state
  • 4
    Big flat bladed screwdriver in the D, twist. – bib Oct 24 '17 at 23:39
  • 25
    It would have been a much nicer story had you been locked inside and the first thing to ask for help was diy.se – PlasmaHH Oct 25 '17 at 11:08
  • 8
    Asked and answered half a day ago. Did OP make it out? – Freiheit Oct 25 '17 at 14:10
    Have you tried knocking? ;) – Machavity Oct 25 '17 at 17:33
    @bib That was very painful to read until I understood the real meaning – anna328p Oct 25 '17 at 19:36
50
See the lock insides? That's a metal sleeve, with an inside sliding piece. That inside sliding piece is connected to the latch bolt. Push it to the left, and voila!
Lock component with where to push
Some additional details. This is what you see when you remove the knobs, shaft and escutcheons from a knob set. The central shaft, which is has a flat, vertical cross-section, goes through that D-shaped hole. Turn a knob either way, and the top or bottom edge of the bar pushes against that sliding piece to open the latch. (Hence bib's suggestion of using a large screwdriver to act as that shaft.)
I believe the smaller hole on the right is for a lock. Push a button on the (interior?) escutcheon and a round shaft is pushed into that hole, preventing the sliding piece from sliding. Low-tech, but quite functional.
  • 4
    I once got trapped in a closet in a similar situation, and the latch was stuck. Fortunately, there was enough space under the door for my wife to pass some tools, and I removed the hinge pins. – GalacticCowboy Oct 25 '17 at 14:18
  • 5
    It took me less than five minutes to answer this, and it's now my third-highest-rep answer across all of Stack Exchange. Rep is weird. – Daniel Griscom Oct 26 '17 at 11:12
  • @DanielGriscom It's a hot network topic on an otherwise low traffic SE site. As long as it keeps garnering upvotes it will continue to be shown network-wide. Enjoy the rep :) – Machavity Oct 26 '17 at 12:41
Lacking any regular tools, a pair of scissors works great.
Open up the scissors to a cross, and push one blade all the way into the hole in the metal part then turn. You can use the other handle as a lever if it is tight.
Hey presto, she be open.
DISCLAIMER: Do not cut yourself or run with this tool, or use your spouse's good tailoring scissors.
    Just link some safety scissors next time – Machavity Oct 25 '17 at 17:34
    Remember to walk to the door, do not run. :) – Chris Parker Oct 25 '17 at 19:02
    This may ruin the cutting edge of the scissors. Don't use your housemate's good fabric scissors! – zwol Oct 25 '17 at 20:39
  • @zwol LOL ... I should add that to the disclaimer... – Trevor_G Oct 25 '17 at 20:47
    Using my wife's good dress-making scissors would be much more dangerous than running with them! – Martin Bonner supports Monica Oct 26 '17 at 13:04
If it is accessible, take the circled part of the door knob and put it into the hole. You'll then be able to open the door.
diagram of a door knob/latch assembly
    John Rawls mentioned in his question that he left both sides inside of the room he was locked out of. – Mark Booth Oct 26 '17 at 10:13
    @MarkBooth He doesn't say that it's the only door handle he has available. Square spindles are standardised, so any door handle spindle will fit any latch. You could even take one off another door (although of course if you've got a screwdriver set then other answers give you quicker ways of solving the problem). – Graham Oct 26 '17 at 12:20
  • If he had a spare @Graham, do you think he would be asking how to open the door without a spare? As it is, I'm not convinced that this requires a square spindle, since the hole in the sleeve is the wrong shape for it. I have never seen Kwikset latch like this though, so can't be certain, but it looks like it might require a semi-circular latch: i.ytimg.com/vi/QXP_9iXv1L0/maxresdefault.jpg – Mark Booth Oct 26 '17 at 13:59
    @MarkBooth I read too fast, sorry. – user60561 Oct 26 '17 at 14:38
