I bought a garden transformer to power 2x 12v 50w Halogen lights near the pool.
https://www.bunnings.com.au/hpm-12v-150w-garden-light-transformer_p4396752
Should I be concerned that the terminals on the transformer aren't weather sealed?
What can I seal these with to ensure no water enters the terminal in case of rain, splash etc?
Thanks
Scott
migrated from electronics.stackexchange.com Oct 23 '17 at 1:52
This question came from our site for electronics and electrical engineering professionals, students, and enthusiasts.
  • Personally I’d use an electrical coating even tho it’s only 12v, the go to product would be scotchkote, but it’s is pricey and overkill for this, but a quick amazon search for “electrical coating” yields a few alternatives, such as this that should be ample and is from a recognized company. – Tyson Oct 23 '17 at 3:01
If you look at the specs on the link in the question, you'll see they claim that the power supply is rated for outdoors, but not for wet locations. It will have to be installed indoors or in a suitable enclosure.
12 volts near a freshwater pool or outdoors where saltwater is not present is not much of a danger. The most likely danger is of burns associated with metal shorting the conductors, like a (jewelry) ring, bracelet, etc. Pressing a tongue against live 12 volt terminals is exciting—but not dangerous.
If you prefer the terminals be idiot proof (which is a reasonable thing for most people) cover them with silicon caulk, though that inconveniences disconnecting and reconnecting. The clear flavor of caulk would be my preference so that one can see what is being protected.
  • 4
    avoid the use of silicon caulk that smells like vinegar or states on the package that acetic acid is released during curing. The acid will corrode metal. – fred_dot_u Oct 23 '17 at 2:07
You can buy silicone filled wire nuts (most commonly sold under the Dryconn brand). The silicone is safe for wires and will help protect from corrosion
  • Are you sure it's silicone or dielectric grease? – Ed Beal Jan 10 at 23:02
  • @EdBeal Their website says silicone – Machavity Jan 10 at 23:38
  • Ok there is also silicone grease, silicone and RTV are used interchangeably in the construction trade. In the electrical trade it is usually called dielectric grease, this is what I believe Fred_dot_u is saying. – Ed Beal Jan 10 at 23:43
  • Took me a few minutes to find the listing information on the ones I have on the shelf. "Moisture and corrosion resistant. Prefilled with 100% non hardening silicone". (I also have a tube of silicone grease it is labeled as dielectric grease). – Ed Beal Jan 10 at 23:58
