House Heating system: Mini Gas Low Pressure Boiler
I have 4 Thermostats in the house (1-Master Bedr, 1-Kids room, 1-guest room, 1-living room) All 3 rooms are generating heat exept in the living room. The living room have 7 baseboard and only 1 of them is generating heat
what would caused the other baseboard to not generate any heat? I check the crawl in, and I can visibly see all the pipes running to each baseboard and i don't see any leak and none of them are warm/hat to touch
