Furnace (oil) wouldn't come on at any setting (fan works). Tried reset button on controller, no noise, nothing. Then noticed the white wire to one of the thermostat terminals was hanging loose, possibly from when serviced last Spring?
Just want to know if I can connect that wire safely (power switch off natch) and not create any other problems. Could there be any reason they left it loose on purpose? We do have air conditioning that is run by the same thermostat (old circular kind) and it ran fine all summer. But now we need heat. Does it make sense that the other things run but not heat with that one wire off? Thanks in advance.
