I know that it is to code to use two 15 Amp Receptacles on a 20 Amp breaker.
Is it acceptable to use a 15 Amp switch that controls the bathroom lights, which is on a 20 Amp breaker, along with an outlet (not switched)?
This is important because I would like to use a wifi-enabled smart dimmer switch, most of which are rated for only 15 Amps.
Thanks!
The answer is yes you can use a 15 amp switch on a 20 amp circuit but the total load needs to be less than the switch rating.
  • This is governed by NEC 404.14(A) BTW. Oct 17 '17 at 22:35
