Bulb in eyeball mount
I think it is a halogen, but I have no idea what kind of light bulb it is. It has a yellow warm light. How do I change it?
Can I use this Halogen bulb removal tool to change it?
Photo of bulb removal tool
I had very similar lights. It looks a bit like this once unmounted:
Unmounted light
So basicly you just have to pull the outer circle down. It's held by two springs, so it should resist a little, but not too much. Once you've taken it out, you will see what kind of light bulb it is.
  • I think the type is called 'GU10@
    – Stese
    Oct 17 '17 at 13:11
  • @Stese The type on the picture I posted is GU10, yes. But on the picture from the question, it could be something else, like the popular MR16. You can't say without seeing the back of the bulb.
    – Legisey
    Oct 17 '17 at 13:49
It's a twist base elevator light. With the same kind of base as an 1156 automotive bulb. You push in firmly, twist to the left, and it should spring out.
