I have a older toilet(1970’s) with Sloan valve flush system- can I replace the Sloan valve with a tank and keep the bowl?
  • Does the bowl have two holes for bolts for securing a tank directly to the bowl? As an alternative, there are tanks which mount high up on the wall and connect to the bowl with a pipe. This has the advantage of having a higher head pressure and so a stronger flush. Is the Sloan valve not working properly? – Jim Stewart Oct 17 '17 at 10:09
  • The bowl is designed to work with a certain volume and speed of flush. A low volume tank would probably not properly flush a bowl designed for a Sloan valve. New toilets probably do not cost much more than a replacement tank. – Jim Stewart Oct 17 '17 at 11:14
  • The bowl is a Crane and I don't see any Holes. there is nothing wrong with the Valve- [just the building management. Insisting it be replaced with tank ( we need To replace all the water risers- 1950 High rise. ]. I am looking for all options – Ldoyle Oct 17 '17 at 12:36
  • Please merge your guest and registered accounts, which will allow you to edit, comment on any of your posts and accept an answer on your question. Thanks, and welcome to the site! – Niall C. Oct 17 '17 at 13:51
