I'm wiring my work shop in Colorado. Its on a separate subpanel off the main panel of my house. Its a separate structure. I wired a series of lights with 14-2 and switched it at the end of the run. At the last fixture before the switch I attached the neutral (white from the power source) to the fixture. I attached the Hot (Black from the source) to a white going to the switch. I attached the black coming back from the switch to the black on the fixture.
In all the preceding fixtures in the run I just hooked black to black and white to white. I believe this is correct though I understand code in some places requires a third wire in the last run to the switch to maintain a neutral. That is not required by my inspector.
The trouble I'm having is this: When I turn on the breaker all the lights come on, however the switch only operated the last fixture in the run.
Additional information that may or may not be relevant:
  1. There is a J-Box between the last fixture in the run and the switch. I just spliced whit to white and black to black
  2. There are other outlets in the run that do not have a fixture yet. Just spliced as a j-box
  3. The circuit shares a breaker with a different switched light. I don't remember how I routed it exactly. I almost forgot to add a porch light and I think I tapped in to the circuit before the first fixture and ran romex to the porch light and then to my 3 gang switch box (same box as the one I'm having trouble with.)
  4. The switch I am using for the end of run circuit that I'm having trouble with is a double horizontal switch. One switch is for the upper lights and the other is a different circuit for the lower lights. I tried using a separate single pole switch for it instead and it made no difference.
I would appreciate any help anyone can offer. Thanks, Peet
You're describing an end branch that is supply-lamp-lamp-lamp-switch with 14-2 cable on each segment.
You have a clear grasp of wire function and you laid it out in black and white (/2 cable is black and white). Trouble is, you're colorblinded. I'd like you to color-code your wires, and I think this will suddenly become obvious.
Get some red tape
(And black too, while you're at it.)
And now tape your wires. First rule of wire is tape both ends at the same time, don't mark one end then forget to mark the other or you'll lose your mind. Second, once you have taped a wire, the wire is now that color. You don't need white tape since you cannot mark colored wires to be a neutral.
Start with the thing that is required by Code: marking your retasked white wire. Your white wire which is always-hot, mark that with black tape. Black is the color of always-hot. **
Now you have a switched-hot wire in that switch loop. You used the black wire which is fine, but mark it with red tape. Red is the color of switched-hot. ***
That was easy.
Whatcha got
Now go to your last lamp box (nearest the switch), remember a marked wire is that color, and you see a very obvious problem.
  • Neutral/white lands on the lamp, as it should...
  • Switched-hot/red lands on the lamp, as it should...
  • Always-hot/black upstream is nutted to always-hot/black switch loop...
  • but nothing carries switched-hot upstream to the other lamps.
Open up the next lamp and you see white/neutral to the lamp, as should be, black/always-hot to the lamp, and that's why they're always on.
Fix it
Now you see, to control the other lamps, you need switched-hot running back to the other lamps. So you need /3 Romex, which conveniently contains a red wire. That's straightforward and I trust you can figure it out.
However there is another Code requirement. You must now run real-neutral on the switch loop.. The reason is for future support of smart switches. So you also need the always-hot, switched-hot and neutral triplet down to the switch. That means you have to use /3 cable on the switch leg also.
That means you can just do the works in /3, which gives you access to native wires with all the right color codes, and I just wasted your money on tape :)
** This is a convention (but a very smart choice when working in Romex.) If some guy in a factory wanted to use pink-with-green-stripe for always-hot, that's his call, as long as he is consistent throughout the facility.
*** That is also a convention, but one which plays very well with the fact that in /3 cable, the third wire is red.
  • Gotcha. That all makes sense and explained very well. Unfortunately I aleardy pulled 14-2 , passed inspection and closed up the walls and ceiling. Fishing an additional conductors now is not really feasible. So I either need to live with adding a switch far away from the entry door or figure out another way to switch it. I make a novice mistake. I thought I could do an end of the run switch with two wires.
    – Peet
    Oct 16, 2017 at 19:14
  • Then yer boned. It passed inspection because wiring lights to be on 24x7 is legal. Now you know, check your work. You can't just rework it to put the switch in a functional but inconvenient location, because switches have to be where the building/electrical code says. Do you really want a paramedic stumbling around in the dark? So either tear down and redo the work, or figure out how to do it with smart switches. Or just leave the lights on 24x7, LEDs are making that cheap. Figure $1/watt/year. Actual watts, not equivalents. Oct 16, 2017 at 21:11
  • @Peet with smart switches you run always-hot and neutral to everything, each lamp has a smart receiver, and the smart switch sends commands by radio. If you have Internet you can also do it with your phone. From Kazakhstan. Oct 16, 2017 at 21:18
It sounds like your run goes like this
  1. Breaker
  2. Fixture
  3. Fixture (not sure how many you have so I'm using 3 for this example)
  4. Switch
  5. Fixture
Because these are wired in series, each fixture is getting fed from the hot and returning through the neutral. You just wired the switch in the wrong spot.
Run wire from your first fixture to the switch, then feed all the subsequent hots off the switched hot. That will let you turn them all on and off at the same time.
  • No sir. I think my description is confusing. Sorry. I don't have a fixture after the switch. For the porch light I tapped into the line right after the panel and before the first fixture in the run. But it seems like the circuit is being completed somehow. I will try disconnecting that porch light tonight and see if that helps.
    – Peet
    Oct 16, 2017 at 16:07
  • @Peet Something has to be after the switch for it to work. That's kinda how switches are designed. I re-read the question and it still sounds like the lights come on when the breaker is switched on, and not when the switch is flipped
    – Machavity
    Oct 16, 2017 at 16:10
  • They all come on when the breaker is turned on. But the switch only operates the last fixture in the run. The one right before the switch.
    – Peet
    Oct 16, 2017 at 19:11
  • @Peet And that means your switch is only affecting the last in the series. You need your switch on the first one in the series
    – Machavity
    Oct 16, 2017 at 19:42
