I built a retaining wall this past summer, and put the proper drainage behind the wall. Due to time, I never got around to handling drainage in front of the wall and in between the pool.
The standing water in front of wall eventually goes away but may take a full day or two. Is this okay for the wall? I have the proper footing, and first row of retaining wall block buried. I tried to grade the area in front so it pitches to the ends, and I'm going to try to dig out and down a little and throw some river rock then dirt, just to relieve some water somewhat.
This past weekend we got about 5 inches of rain, the water was maybe an inch in front of the wall. Worst case, I have a water transfer pump to relocate it, but I'm planning on throwing river rock around it and just leaving it, if it's not going to hurt the wall, and it will eventually go away on its own anyway.
I don't have the energy to dig into the clay and move all that earth for the proper french drain. This summer I already, installed a 100ft french drain in my yard, dug out the pool, installed the 130ft electrical run for the pump, installed the retaining wall, and installed sod. I'm beat; and I have other pressing projects to fulfill, before winter gets here.
Pictures:
1) https://imageshack.us/i/poeZRuvfj
2) https://imageshack.us/my/images
I can live with the water and hopefully the river rock will disguise it, keep it under it until it drains away. I just don't want the footing to eventually shift and collapse the wall.
The foot is your typical footing material crushed stone with fines, and tamped 6 inches or so deep, and then the wall block. The base is 2ft wide, and then gravel on top of it in front and behind the base block. Then on the top in between the pool and wall is sand and gravel mixed, and then I plan to put down landscaping fabric and put river rock all around the pool.
