I am trying to work out how much my kitchen floor slopes before putting in a flat pack kitchen. The spirit level says it is a 2 degrees slope so how much does it drop over a metre? Appreciate any answers.
closed as off-topic by isherwood, ThreePhaseEel, mmathis, Daniel Griscom, JPhi1618 Oct 24 '17 at 19:07
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
    That's a massive tilt. I seriously doubt it's that much. You need a full-length level of high quality (or a rigid straightedge with a shorter level), and you need to reverse it to check for error. – isherwood Oct 14 '17 at 14:32
  • Tan(theta) x 100 will give you slope as a percent, or cm/m. So a 2 degree slope is 3 cm/m, which is quite a bit. Typical allowable deflections in building codes are 1/180 (approx 1/3 of a degree) or 1/360, depending on the application. – Chris Cudmore Oct 17 '17 at 13:07
tan(theta) = rise/run
tan(2 degree) = 0.035
That would be a 3.5cm drop over a 100cm run.
  • Thanks for that, sounds about right according to the kitchen bloke who visited – Jduffy Oct 14 '17 at 6:46
You can use trigonometry if you have access to a reference. For small angles (less than about 10 degrees), there is a handy approximation that is very close and easy to remember. If you have the measurements (rise or drop and the distance), the angle in degrees is approximately rise/run * 400/7.
In your case, you have the angle and the run, so you can transpose to find the rise (or drop in your case): for 2 degrees and a run of 1 meter, rise = 2 * 7/400 * 1 meter = .035 meters or 3.5 cm.
