I thought I sand my floors myself so last night I rented random orbit sander from home depot. Using the 36 grit sand paper. I did not get the result I was hoping to get. It is my first time using the sander. Upon closer look, I found that some of the planks are not even. Some planks are higher some are lower due to which I feel like the sander didn't do a good job. What do you recommend I do at this point? Should I rent the drum sander? Here is the result. Close up pictures show better result.
10/15/2017 UPDATE: I decided to hire someone to do this job. I found a lot of mix reviews. I personally didn't feel comfortable using the drum sander which is exactly what this floor needed. The drum sander that they used was 220 volts and was way more powerful than what I could rent. Here is the latest picture. enter image description here enter image description here enter image description here enter image description here enter image description here enter image description here
10
    What sort of sander did you rent? Unless it's large (standup-style), it's not going to get you good results in under a month. You need a machine capable of taking material off a large area in a reasonable time. I used a plate sander from a rental shop. Drum sanders are not for the novice. They'll give you divots in a hurry.
    Oct 12, 2017 at 14:57
  • If that is what you're using, how much time did you spend? A room like that could call for several hours of sanding.
    Oct 12, 2017 at 15:00
    This job definitely needs a proper floor sander. If you do rent a drum type, try to find somewhere to practice first (big piece of scrap plywood or something), because as isherwood said, it's easy to go wrong.
    – brhans
    Oct 12, 2017 at 15:21
    @isherwood Room I think is 13x14 give or take. I used the Random Orbit Floor Sander from home HD. Made by Clarke American Sanders. It has 3 round disks. I spent about an hour and a half after I realized this is not going to work any further. I've never used Drum sander before and it sounds scary.
    – Sam
    Oct 12, 2017 at 15:51
  • Did you change the disks at any point? I'm not familiar with them, but they may have worn out.
    Oct 12, 2017 at 16:11
It's hard to tell without pictures or exact model number, but based on your comment you've probably rented a buffing (finishing) floor sander not unlike this one. For very uneven floors you should have indeed started with a (flooring) belt (or drum) sander. Belt/drum sanders (flooring or otherwise) can remove a lot material quickly.
Even Home Despot's own video recommends you get a drum/betl sander for solid wood (as a start). The orbital sander they rent is for finishing. They say nothing about their random orbital, and I suspect it will work by itself, but slowly; you'll probably have to change discs 4-6 times (in each pass) for the entire surface you have to make steady progress. I can't tell from the pictures how uneven your slats are or how much extra time (and sanding discs) that might take.
Dealing with the height differences is a little tricky even with a drum/belt sander: you'll probably want to sand at 45 degrees initially so the sander never rests on a single slat (or entirely misses the adjacent one), then go with the grain for the subsequent passes. I'm guessing you can achieve the same effect as 45-degree drum sanding with a random orbital by hovering long enough in an area until it levels itself. YMMV.
A NYT article on the topic also has this interesting titbid:
Some online sources recommended the U-Sand sander [which seems to be a random orbit sander with four discs -- my note], which theoretically eliminates the need for a drum sander and a buffer. The manager of my local rental agency tried to talk me out of it, saying seven out of 10 people trade it in for a more powerful drum sander.
And the reporter also had issues with the U-Sand: even after using it for four hours he couldn't get to all the "valleys" in his floor. So unless you have oodles of time at your disposal, a random orbit sander is probably not the best idea for a floor that's pretty uneven at the start.
Clarke has quite a bit to say about their multi-purpose random orbital (which just as the U-Sand is intended to replace both the belt and edger) but what I read into that marketing (especially if you compare to what they say about their drum and edger) is that it's a gentle machine wiht low risk of wrecking floors in the hands of the untrained, but in the subtext that also says it's rather slow in removing material or making progress with uneven floors. The same user experience with respect to dips/valleys has been reported for the Clarke random orbital as well.
    It was Random Orbit Floor Sander made by Clarke American Sanders. Model # 07163A. I also added pictures above. Just to also add, This sander was recommended by the person who works there. Now I suspect, they had no idea what my floors were like.
    – Sam
    Oct 12, 2017 at 19:33
  • @Sam: Probably they didn't. For uneven (cupped) floors even Clarke recommends their drum sander instead because of the amount of material that needs to go. Oct 12, 2017 at 20:28
A random orbital sander is not the proper tool for this job. You need to rent a proper floor sander for the field. These tools provide even pressure across the sanding path (about 12" wide, typically), which is why they weigh close to 100 lbs.
You may get by with a random orbital sander for the perimeter, but you should consider renting a proper edger, too. The edger is essentially an orbital sander with a heavy motor and case. They can be unwieldy if you haven't used one before. When I did my floors, I ended up using my random orbital sander for the perimeter after I put a couple deep grooves into my floorboards with the edger. It took twice as long with my random orbital sander, but the results were better.
You should also consider starting with a coarser grit for your first pass. 24-grit is typical for older floors.
  • I think the OP established in the comments that (s)he did in fact rent a flooring sander.
    Oct 12, 2017 at 16:12
I refinished my floors last year. I initially used a random orbital sander, however the sand paper would clog up after about 10 ft of you. So I took it back and rented a drum sander. This was a faster and easier way, just don't sit in one spot, always be on the move.
