I started removing what I believe to be 12x12 ceramic tiles which I’ve found out are adhered to a concrete backerboard which is adhered to a plywood subfloor. I’ve scoured the internet and have found some similar questions but nothing which fully satisfied me. Basically, my tiles are chipping in tiny pieces when I am manually chipping them off with a chisel/hammer and I’m looking for a more effective, less time consuming, less intensive method to remove them. I was initially going to try and keep the backerboard but it’s getting a bit chipped up and since it’s so inexpensive I’m thinking of just ripping it out as well. I was thinking about buying a rotary hammer with a chisel blade and going to town but I was wondering if anyone had any ideas or tips that might help me out? I do have a decent amount of power tools in the garage so if another tool is the answer I might have that lying around. I have not seen any screws in the backerboard so far (I’ve only gotten off like 8ft^2 of tile, though) but I was also worried that if I tried to lift/remove the backerboard and it did have screws that I didn’t find it could damage my subfloor, which I am obviously hoping to avoid.
Thank you so much for any assistance anyone can provide!
