I was swapping out the gears in my garage door opener and when I plugged it back in I heard a pop and some smoke, unplugged it immediately and realized that I had pinched a wire with a screw that I had totally not noticed. I can see on the circuit board that something blew out on it and it looks like the wire leads to the light that is supposed to come on when the garage door opens/closes. The light doesn't work but I am honestly not sure if it worked before as the others don't but the garage door itself works fine.
I wrapped the wire that I messed up with electrical tape to prevent any raw wire from being exposed but my lack of electrical knowledge has me worried that this is a dangerous situation. Should I be concerned to leave the garage door opener powered?
  • Does the opener have a metal chassis? I assume so because of the fireworks. Is it grounded? I assume so, ditto. – Harper - Reinstate Monica Oct 10 '17 at 14:38
If you damaged the wire then it is possible it is no longer capable of safely operating under the load that is called for. This is a potential fire hazard since it may result in the wire overheating.
You should replace the damaged part of the wire. Depending on circumstances of the wire (which you haven't fully detailed) you may be able to cut out the damaged section and splice the resulting free ends together (or splice a replacement section in to the gap). You should use proper splice hardware for the task, which could well be a simple wire nut (though this depends on the type and gauge of the wire as well as the service conditions - eg, wet or dry, exposed to oil, gas, etc).
If you are certain that the insulation and only the insulation was damaged (ie, the damage is no worse than would have been incurred had you been stripping the insulation from the wire with the appropriate tool), electrical tape may be a sufficient repair - again, considering service conditions.
It's hard to say whether the damage to the circuit board will result in dangerous conditions or not. Chances are, everything on the board is sufficiently low power that there is no danger - but with the information available here, we can't say for sure.
| improve this answer | |
There are two basic concerns
  1. The electrical safety: As long as the wire is wrapped in electrical tape and not touching anything you should be fine. There are lots of wires in your house that have electrical tape on them. This is what electrical tape is used for.
  2. The safety of the garage door opener: When something blew there may be damage that you are not accounting for. Test every safety feature of the garage door opener including but not limited to the safety eyes and auto reverse. Also, make sure the remotes and keypad/inside button still work. If you are satisfied with the operation of the undamaged systems then you can continue to use it.
Any one that tells you that it is safe from this distance is a fool. Yes it may be safe, but you will need an expert to look at it.
After the repair, an electrical safety test should be done. This should be at minimum: checking the circuit diagram of the device, a visual inspection of the device, and a PAT test, or equivalent electrical safety test.
Call an electrician, they can do every thing that is needed to check that it is safe.
  • What tests should be done, and what equipment is needed? This is a site for DIYer's, and while some things are definitely best left to the professionals, knowing what to ask for / expect is very valuable advice as well. In addition, this site prefers specific answers rather than broad generalizations, even if it is not something a typical homeowner / DIYer will have or be able to do. – mmathis Oct 10 '17 at 16:26
    Added some info on testing. However you are not electrically competent then don't risk it. There is not enough info in the question. With a circuit diagram, and a competent description of the fault. Then a better answer is possible. – ctrl-alt-delor Oct 10 '17 at 16:34
    DVing because PAT tests are specific to UK and a few other parts of the world -- if you asked a North American electrician to perform one, they'd give you quite the blank stare! – ThreePhaseEel Oct 10 '17 at 22:23
