Much like the title of the questions says; my HOA had to have a plumber come out to replace the risers for the building.
After they finished, I noticed that half my unit was without power.
Electricians came out and found that a wire inside of my conduit was broken. The wire appeared to have been pulled too hard and snapped (this is a little bit of conjecture, we can certainly say the wire was not cut). The total cost for the electricians to come out, identify the broken wire and replace it was ~2,000.00 for me.
Can/should I bill the HOA or the plumbers for the repair work that needed to be done to me wire?
closed as off-topic by mmathis, Ed Beal, Tester101 Oct 9 '17 at 18:28
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
    I'm voting to close this question because contract disputes are off-topic – mmathis Oct 9 '17 at 17:01
  • You might have handled those details before you hired the electrician. At this point you are saying "because of you..." And will need to prove it. – Harper Oct 9 '17 at 19:45
First off....WOW! Two grand to troubleshoot and repair a broken wire? That's sounds waaay high. That should cover a Journeyman electrician for a week. I think they based their price on the value of your home.
Second, if everything was working fine prior to the plumbers visit I would definitely ask for a back charge from your HOA.
Good luck!
