I shut the valve off on the Hammer Arrestor, then added an inline water filter, but when the valve is on no water is coming out. Do I need to turn the water supply off to the house and then turn it on again to get the water flowing into the refrigerator?
    Did you remove any seals the new filter had? No you don’t need to turn off the house main, you have another problem. – Tyson Oct 9 '17 at 1:08
  • Agree with Tyson , also have you Tryed to flow the water for several minutes you need to purge the air out of the filter and water lines that may have drained out. – Ed Beal Oct 12 '17 at 22:55
