I want to paint over factory finished kitchen cabinets.
I plan to sand them and brush primer with oil based paint.
I plan to use an alkyd paint I was told will make a nice finish.
Home Depot warns me to use only latex in their rental sprayer.
What can I thin the alkyd paint with to safely use in the sprayer?
YOU DON'T!!!
Do not put alkyd (oil) paints in a sprayer not made for them. They will destroy the seals. The act will be detected. That is a very expensive way to buy a commercial grade latex paint sprayer that only works on latex paint and is now ruined.
You'll need to buy a proper spray gun made for aklyds, epoxies, LPUs and the like. I have been delighted with this little guy, I run it at 10-20 pounds and it works great.
Honestly unless you are well practiced in the art of spraying, you may be better off sticking to brush. Google "$50 Rustoleum paint job" for tactics to get near-spray-finish out of common alkyd paints.
P.S. there is nothing lowly or amateur about brushing. I do my best work brushing $300/gal. aircraft grade LPUs (because the stuff is extremely toxic to spray, whereas with brush, you only need gloves).
