Hi I have a 1950s house in Indiana that has the original wiring to a detached garage. The garage is about 25-30 feet from the main panel. It currently only has a switch for the light.
I am planning to run a welder, and air compressor at some point so I would like to install a 110v and maybe a 220V since I am going to run the wiring.
Should I run a subpanel to the garage or can I run two dedicated circuit arms to the garage with a shutoff in the garage?
Any other suggestions are appreciated. Here is a picture of my main panel.
