i have Samsung washing machine from UAE, the cord is without plug, when i moved to the UK I bought the plug and found that it is fitted with a 13 amp fuse
My washing machine has the following label : 220-240v 2000- 2400w
And i found the instructions in the manual is to plug the power cord into an AC 220 V/ 50 Hz/ 15A wall socket or higher
Will there be a problem connecting the cord to this 13 amp fused plug and then to the wall socket in the UK?
  • What model is the washer? Oct 2, 2017 at 22:36
  • From something I found there are also 2.5 A sockets available in UAE. They would not be suitable for the washing machine, so they have to say to plug it into a different type of socket, i.e. one which is capable of supplying 10 A, which a 15 A socket is. Oct 3, 2017 at 14:45
There's no reason for a washing machine to use that much electricity unless it's heating the water.
If it's heating the water, it's using a resistive element. With those, if voltage changes a certain percentage, power drawn changes by the square of that percentage. So looking at the specs, it is 2000W at 220V and 2400W at 240V. The new voltage is 109% of the old, square that and you get 119%. The new wattage is 120% of the old. Close enough: it is behaving like a resistive element.
2400 watts at 240V, that is 10 amps, which is obviously under 13 amps by a margin. You should be fine.
