If I strip an insulated wire, and the wire under the insulation is dark, not bright, and it's this way not just at the end but in the middle too, should I discard that wire for use? Has it been damaged from too high resistance?
    Dark as in just dark, or dark as in corroded? Wires aren't damaged by resistance, but by heat melting the sheathing. Got a picture? – Machavity Sep 28 '17 at 17:38
  • What Machavity said plus copper oxidizes and turns dark. It could have oxidized during manufacture or later. Usually not a problem unless you are trying to solder it. – ArchonOSX Sep 28 '17 at 17:50
  • oxidation may indicate its been exposed to moisture. To a certain degree you can still use it if you take care to remove the oxidation at any connection. That said there are all kinds o fwire and applications, its hard to be generic. – agentp Sep 29 '17 at 0:10
-1
It can oxidize, but if you can test it for connectivity it should be fine.
