I had to silicone seal a small gap around bottom joint of our shower screen, where it is attached to the wall. We realised that a small but steady drip was soaking the floor over time. I sealed it fully about 7pm and it seemed 'set' following morning. So I used it, but still a small drip was magically seeping through.
So, could this be because after 14 hours it had not cured properly, or more likely I simply did a bad job? If it was because it was not properly cured, have I now ruined it? EIther way, can I simply plug in some more or should I start again?
Thanks for any advice guys.
