I bought the Craftsman fixed-based router + table for DIY home projects. I am in the process of getting familiar with the router/table operation + safety rules. I have the following questions.
- Generally, how high does the router bit need to be positioned with respect to the stock? For example, in the picture below I have a 3/4'' block and am using a 1/2'' cove bit. Where should I set the bit? Are there any rules/tips guide?
The user manual advises multi-pass routing with cut depth being 1/8'' max/pass. Does this mean that when I align the router fence it should only expose 1/8'' of the bit? The depth is in the X (lateral) instead of the Y (vertical) direction?
There is a guard on my router table. During operation, do I flip the guard up or leave it on (for safety) and slide the stock through it using push pad/stick? For example, in table saws the guard should always be present for safety. I have been looking at a bunch of Youtube videos, and all of the router tables don't seem to have a guard.
