I replaced my old diverter spout with a new one (both Delta), and I've found that the new one will leak water back through the hole in the wall if the diverter is switched off while the shower is running. hole in the wall
If I first turn off the water pressure and then push in the diverter, no problem. So, seems to me that the issue has something to do with the onrush of water when the diverter is switched off while under pressure. I'll just mention that our water pressure is typical (wimpy) for Southern California.
The new spout has a copper piece that screws onto to the water supply from the wall: copper piece
...and then the spout screws onto that until it's flush with the wall (there is no set screw). the spout
If I block the spout with my hand and try to blow air through it from the back (with the diverter off), I'd expect flow to be blocked. Instead, I can feel air escaping out of the holes in the back. holes in the back
What puzzled me when I was installing this (there were no instructions) is that it doesn't seem to be designed to seal against the wall or prevent water from getting into the outer body of the spout.
Anyone know what I'm doing wrong? Any advice?
I need to finish this up so I can repair the drywall in the downstairs ceiling.
Cheers!
    Something is very strange with this design. If water gets between the threads with the PTFE tape and the O-ring, how wouldit get out? The only way this can work is if the O-ring makes a complete seal and water never gets past it. Take the PTFE tape off the threads, put silicone grease on the O-ring and thread the spout on firm. The threads are not designed to hold back water so no sealant is needed on them. Those threads are designed to hold two other sealing surfaces together and the PTFE is interfering with tightening the spout as it should be. Jul 29 at 19:16
  • When you unpacked this spout system was the plastic inside fitting separate from the metal spout? Did you screw on the plastic innards to tightness and then push on the metal spout? If it only leaks when you release the diverter "under pressure", then you ould get it to not leak if you would first turn the water off and then release the diverter, right? It could be that you are not supposed to seal the spout to the wall on the bottom side. If the bottom is left unsealed then any water which drains would go into the shower and not be forced into the wall. Jul 31 at 21:55
How do you know water it leaking back into the wall. I can't quite see from your pictures, did you uses plumbers tape between the copper threads and the new brass piece (three times around, in the direction of the threads)?
I've installed some of these spouts. They never have a set screw. Once the rubber seal is well inside the spout water shouldn't get back there, unless there is a leak between the copper and brass.
The diverter isn't air tight. When water hits the diverter it gets pushed tight making a water tight seal, your breathe can't push it enough to make that seal.
  • Old fixtures were leaking, causing sagging ceiling downstairs. Cut a hole in the ceiling to ensure fix before replacing drywall. New setup drips a little, ONLY when I disengage diverter under pressure. Sep 18, 2017 at 17:40
  • Didn't know the 'three times around' rule (committing that to memory; thanks), but yes, I did use Teflon tape, in the direction of the threads. Sep 18, 2017 at 17:42
  • Good to know about the diverter water/air tight thing. Thanks for that. :-) Sep 18, 2017 at 17:43
I know of no tub spout that is, or is designed to be, watertight. It is the hole in the wall from which the spout supply pipe emerges that needs to be sealed. This can usually be accomplished with caulking around the pipe, but pointlessly large holes such as shown in poster's photos make that extra hard. Better tile supply vendors sell "rubber" gaskets that grip the spout pipe snugly, but that is something that must be installed prior to the finish surface.
Something is very strange with this design. If water gets between the threads with the PTFE tape and the O-ring, how would it get out? The only way this design can work is if the O-ring makes a complete seal and water never gets past it.
It may be that the front flat of the threaded area is supposed to be tight against the plastic. The strands of PTFE are interfering with that.
Look inside the spout to see if PTFE tape has gotten into the O-ring sealing area and if so remove it. It would interfere with the O-ring sealing.
EDIT
The brass fitting screws into a fitting which is soldered (sweated) onto the copper pipe. The threaded joint must be sealed with pipe dope and/or PTFE tape. I personally prefer pipe dope. This joint might be poorly sealed and leaking. If you think it might be leaking, unscrew this joint, clean it out and apply good quality pipe dope or PTFE tape, then reassemble.
