I'm in the process of renovating a bedroom on the second floor and I have a few boards of silverboard (a Polyisocyanurate Foam Board Insulation) lying around and would like to use. The exterior wall is brick followed by a spacing followed by another wall (some sort of concrete). Since the silverboard has radiant shielding on both sides and sandwiches a stiff foam board, would I:
1) install the silverboard in contact with concrete wall, or
2) leave a spacing in between the concrete wall and the silverboard?
18
    Are you installing the insulation on the inside or the outside of the concrete wall? Sep 15, 2017 at 4:18
  • The insulation will be on the inside, it's my first time using such a product. If it was regular radiant shielding then I would leave a gap, but because this has a foam board it complicates matters. Sep 15, 2017 at 4:21
    Does the wall already have a vapor/air barrier in the assembly, or is it a pure mass wall with no insulation or barrier layers? Or is it ICF? Sep 15, 2017 at 4:22
  • To @ThreePhaseEel's point, do you already have insulation on ... I mean, IN the wall? I would not use foamboard at all inside of the wall. Instead, I would use a roll foam or heck, the messy "new" spray foam. but not a foam board. it will not serve its purpos inbetween joists, and you do not want it compressing under a drywall either.
    – noybman
    Sep 15, 2017 at 4:25
    No vapor barrier, no insulation, its just a brick wall on the outside and a slab on the inside. There is an air gap in between the brick wall and the slab, also no ICF. Sep 15, 2017 at 4:28
