I currently have an 24ft intex Pool. I know it doesn't have to be bonded but while the yard is torn up I am thinking it may be a good idea to run the bond wire now for when I upgrade the pool to a permanent one.
The problem is, I have a retaining wall on one side with a 24 inch tamped rock base, and about 6 to 8 inches of gravel behind the wall.
So this wall falls within 18 to 24 inches from the pool wall for where to put the halo copper wire.
Where should I put this wire?
The retaining wall blocks are 11inches deep. When i last measured, right behind the wall was 25 inches to the pool wall. And the 18 to 24inches rests over this wall area.
