Our new house is still under construction by a standard builder. After the home is finished, I will be installing a small mini split ductless AC system for a home office that will get much warmer than the rest of the house.
I received permission from the construction manager to run a cable from the breaker to an outdoor wall, so that I would not have to tear up the drywall or run conduit from the breaker to wherever the compressor will go. I will not be installing the wire into the breaker, or the outdoor outlet, until after we have closed on the home. It will essentially be a dead wire sitting in the wall until I add it do the breaker and then add the outlet.
That being said, I am not sure if the compressor will be a 110v or 220v configuration (I haven't decided on a unit). What would be the best cable to run to ensure that I can either install a 110v outlet or 220v outlet using the same wire? Is this possible?
Also, what should my outdoor outlet look like? Is just an outdoor junction box sufficient or should I use something similar to a non-fuse metallic disconnect?
Thanks for the help!
