Is there a code that states whether a pigtail is required for each outlet or if the second screw on each outlet can be used to continue current to the next outlet in the series? Since the only connection is that thin metal clip I was wondering if that is considered a proper connection versus wiring a pigtail into the connection for each outlet so that all wires are interconnected at each box.
For what it's worth...if pig tailing, are Wago or similar push in connectors allowed or must it be an actual wirenut?
